edge jwa
Old Jun 11, 2010 | 11:00 AM
wyodiesel92's Avatar
Default edge jwa
I'm probably picking it up next month and I'm just curious how long should it take to put in? I figure the longest part will be running wire to the monitor in the cab or tapping the pump?
Old Jun 11, 2010 | 11:23 AM
jkidd's Avatar
1.5 hours if its your first time.
Old Jun 11, 2010 | 12:44 PM
RAW's Avatar
RAW
You should be done in 2 hours, including installing the pyro. I suggest the use of a stealth plate as well. Cleaner, and I think it makes a much better connection to the pump.
https://www.dieselbombers.com/5-9l-2...e-install.html
Old Jun 11, 2010 | 05:06 PM
Yeah I planned on getting a stealth plate, it comes with fuel pressure too right?
Old Jun 11, 2010 | 05:19 PM
Matt Tex's Avatar
Yes it has a fuel pressure sensor.
Old Jun 11, 2010 | 05:28 PM
cumminsdad08's Avatar
i installed mine in less then an hour, but the hole was already drilled for the pyro, and i don't have a gauge for the pump.
Old Jun 11, 2010 | 06:21 PM
RAW's Avatar
RAW
I sure hope you have some type of low fuel pressure warning device!
Old Jun 12, 2010 | 02:46 PM
Very nice setup I am currently running one on my 01. Fixing to change my Attitude monitor to a CTS or CS.
Luke
Old Jun 12, 2010 | 02:58 PM
crzycummins's Avatar
its a gravy install
Old Jun 12, 2010 | 04:21 PM
Well now parleysdieselperformance doesn't carry it so I guess I need to find somewhere else that is selling it as cheap as they were at 600
