heavy white smoke.........
Old Jun 10, 2010 | 11:24 PM
stock 24 v's Avatar
Default heavy white smoke.........
i have a 01 2500 quad cab 2wd , just need a little input
every morning i wait for the (wait to start) light to go out
then when i start it it smokes heavy white for a few seconds
and then want do it again til the next morning , thanks in advance
for the info.
Old Jun 11, 2010 | 06:50 AM
RAW's Avatar
RAW
Is this a recent thing, or has it done it for a while? Were there any events leading to this symptom? It's more than likely unburnt fuel because the engine is cold.
Old Jun 11, 2010 | 07:40 PM
stock 24 v's Avatar
it started recently cause it did not do this during the winter months
Old Jun 12, 2010 | 09:50 AM
outlaw1_gt's Avatar
fill out your signature, tell us what you have done to your truck...
Old Jun 12, 2010 | 09:02 PM
stock 24 v's Avatar
i can't say anything bad about it , just the white smoke , i only
give $4k for it and it don't need anything at this time .
Old Jun 12, 2010 | 09:57 PM
crzycummins's Avatar
well if your gettin heavy white smoke it needs somethin...heavy white smoke means your not gettin enough fuel...black smoke is too unburnt fuel...but i do agree with rawilliams...it will happen more in the cold.
Old Jun 12, 2010 | 10:36 PM
RAW's Avatar
RAW
Keep an eye on your coolant level.
When it starts, does it run rough for the first bit? I am asking to try and tell if the intake grid heater is working. Can you tell if your voltage drops as the heater cycles? Dimmed lights, load on engine, both good ways to tell if you don't have a voltage gauge or multimeter.
If everything is working there, It's not a huge job or a big cost to get your injectors pop tested. I was charged $22 for nozzle swaps and pop testing when I changed mine.
Old Jun 12, 2010 | 11:59 PM
stock 24 v's Avatar
i'll check all of that, thanks. i do know that
my (wait to start) light comes on then goes
out as fast as you can blink an eye.
Old Jun 13, 2010 | 10:42 AM
RAW's Avatar
RAW
Maybe check this out:
Ram Diesel Manifold Heater Problems
Almost sounds like your AIT (Air Intake Temp) sensor may be failed. At temps under 60F the heater grid and wait to start light should come on for 10 seconds. If it is warmer than that in Knoxville, and I see that it is, then the light and grid will not come on.
Old Jun 15, 2010 | 11:14 PM
stock 24 v's Avatar
thank you guys alot for the helpful info.
i removed the IAT sensor and cleaned it with
camping fuel works real well and replaced
the fuel filter with one from napa
and will not buy another one from advance or autozone
again , and again thanks for the info.
