fuel shutoff
Old Jun 9, 2010 | 08:46 PM
casper83's Avatar
Default fuel shutoff
i have a 96 3500 12v. i have been trying ti figure out why my truck seems like it is lacking in power. i have a manual fuel shutoff cable because it doesnt have a silenoide or even a mounting bracket. when i push the cable in the truck will start just fine. yesterday it crossed my mind to check how far the shutoff was pushed up. i pulled on it and it moved another 2 inches forward, and when i drove it it seemed like it had more power. is this possible that it was starving for fuel or was it just wishfull thinking?
Old Jun 9, 2010 | 09:47 PM
94 12valve's Avatar
yes, the shutdown must be pulled all the way up other wise it will cost you fueling and power
Old Jun 9, 2010 | 10:06 PM
jrad989's Avatar
this exact same thing is happening to me. it used to work fine. trust me you are starving your truck for fuel. i just have a cable on the floor i pull to shut it off. so i am almost positive that between the dirt from my shoes on the floor and the dirt from going through a few big mud puddles the cable has just got full of of dirt because it is one small cable inside a larger one so dirt can get in. I am about to pull the cable and give it a good clean and lube and it should work again. ill tell you if it works.
Old Jun 9, 2010 | 10:10 PM
casper83's Avatar
thanks guys. i hope to get everything straitened out and maybe finally get my pump turned up.
Old Jun 9, 2010 | 10:14 PM
FastCR's Avatar
it definitely makes a difference, thats part of the reason i went back to a real shutoff. I used to have the exact same problem, i thought it seemed sluggish and it turned out i didn't have the cable in all the way. You could also put some spings on it to hold it open, but I honestly wouldn't risk the runaway risk again, i took mine off just thinking about what could happen.
Dbleo351
Nov 20, 2016 09:34 AM
Cavnar
Sep 9, 2015 07:18 PM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
