white smoke
Old Jun 9, 2010 | 07:12 PM
cummins-dodge's Avatar
Default white smoke
on my 01 twin turbo cummins i was woundering why is my truck blowing white smoke at idle and while i am going down the road could it be just the 250 injectors i bought a used s300 when i did my twins and the waste gate does not move could that be the problem
01 dodge quad cab 5spd 274000 miles cold air intake afe, cooler tubz, duel electric fans, airdog 150, edge juice att. hot unlock, schied lighting pump, .093 connector tubes, ats head studs, 250 hp injector, s400 turbo and s300 twins, cooling mist water meth injection, duel 6 inch aussy stacks, 4 inch lift, eagle alloys, 35x12.50x16.5 bfg's, ranch hand front and rear bumpers, valiar on board air with Siberian express train horns,
01 dodge reg cab 5spd 273000 miles cold air intake afe, cooler tubz, single electric fan, Holley blue pump, edge juice att. hot unlock, .093 connector tubes, duel 5 inch miter stacks, leveling kit, American racing wheels, 33x12.50x16.5 bfg's, ranch hand front and rear bumpers
84 chevy k30 reg cab with 94 12v p pump cummins and nv4500 trans 205 transfer case 3 inch body lift, 6 inch suspension lift, 36x14.5x16.5 parnelli jones dirt grips, 16.5x12 weld scorpio wheels, dana 60 front, duramax rear axle, duramax intercooler, schied custom injection pump, 370 injectors that are extude honed bigger, o- ringed and head stud, marine lift pump, custom ground cam, cooling mist water meth. injection, single 5 inch miter cut stack
03 honda rincon 650 1500 miles with 2 inch lift, 27 mudzillas, 1 1/2” rear wheel spacers, 1 inch front wheels spacers, hmf pipe, dynatek cdi, dynatek coil, k&n air filter, rejeted, spring clipped 8 coils, 5000 lb winch, heated grips, 14% gear reduction, 2 inch snorkel
95 yamaha warrior 350 bored out to 366, stage 2 hot cam, JE 85mm piston 10.5:1 compression, new rod, k&n air filter, white bros. pipe, bigger coil, performance cdi box, nerf bars, oil cooler mod
82 honda odyssey fl250 k&n air filter, dg pipe, rejeted FOR SALE
07 Kawasaki klx250 on offroad bike moose air filter, fmf pipe mostly stock
Old Jun 9, 2010 | 07:49 PM
RAW's Avatar
RAW
Are you loosing any coolant, and not seeing a puddle? If so..... head gasket. Does it happen all the time, or at certain temperatures or loads? When did it start happening?
Old Jun 9, 2010 | 10:23 PM
Blue01cummins's Avatar
i would say it is unburned fuel. that aint good thought if it is washing the rings out.
Old Jun 9, 2010 | 10:31 PM
crzycummins's Avatar
if im not mistaken...white smoke equals underfueled. are you getting plenty of fuel to those big injectors?
Old Jun 9, 2010 | 10:57 PM
ArizonaRedneck's Avatar
whats your exhaust smell like fuel or maybe coolant are you losing any coolant or is your engine oil getting thin or smell like fuel and is it smoking constantly when going down the road
Old Jun 11, 2010 | 01:02 AM
White smoke is from unburnt fuel or moisture in the combustion chamber.
Old Jun 13, 2010 | 02:14 PM
i am not losing any antifreeze the oil is still thick and does not smell like diesel i have a air dog 150 on it have i have 14 to 17 psi the smoke smells like diesel could it be a blown head gasket that is blown between the cylinders the truck still has alot of power or could it be that my injectors need to be pop tested they were used off of a different truck that had less that 5000 miles on them he sold the truck so i got the pump and the injectors off of him
mattshow123
14
Mar 12, 2018 01:41 PM
coolf250
Dec 2, 2017 12:30 PM
Blakeishere
Ford Powerstroke 08-10 6.4L
Oct 6, 2015 10:54 AM
sgreen3
Feb 24, 2015 03:34 PM
zoomer10h
Feb 6, 2015 01:38 AM
