hey
Old Jun 9, 2010 | 01:44 PM
dodgecummines12valv's Avatar
Default hey
hey guys will it help if i put little air filters on my valve covers
Old Jun 9, 2010 | 01:46 PM
FastCR's Avatar
with? It helped with my oil leaks, after I upped the boost i had enough crankcase pressure i was pushing oil out of a few places.
Old Jun 9, 2010 | 07:57 PM
jrad989's Avatar
fill out your sig buddy. people typically use those when they have twins that are puttin out a ton of boost.
Old Jun 9, 2010 | 09:33 PM
94 12valve's Avatar
it will help with your crankcase pressure. altho if you have a lot of pressure on a very stock motor something else is clearly wrong.
Old Jun 9, 2010 | 09:52 PM
FastCR's Avatar
x2. what are your issues? I put it on more as a temporary fix because my side cover was leaking. It did help, but its not a fix unless you have enough cylinder pressure that its causing high crankcase pressure.
Old Jun 9, 2010 | 11:14 PM
dan33klein's Avatar
i am running twins with high boost, what are these airfilters now?
Old Jun 10, 2010 | 09:12 AM
94 12valve's Avatar
there not air filters, there crankcase breathers
Freezzman
Aug 4, 2015 10:05 AM
Captainstubs1
Jun 16, 2015 03:50 PM
mineman_bruce
Mar 1, 2015 11:36 PM
ItsAChummins
Nov 30, 2014 11:05 PM
