raptor pump install
Old Jun 9, 2010 | 06:11 PM
c0zgrove's Avatar
Default raptor pump install
hey guys i was wondering what do i need to do with the intank pump after i get my raptor installed cuz i did everything by the instructions and diesel is pouring out of the old supply line
and what turbo would be better for towing a 62mm with a 13cm or 14cm housing
anybody?
Old Jun 9, 2010 | 11:06 PM
mxtuner1's Avatar
14 is the one less back pressure for lower egt's - anything we do to lower egt's is good as you can always hit max egt's whilst towing.
Old Jun 10, 2010 | 09:17 AM
dangerous1965's Avatar
I hope you cut the power wires to the old pump! Did you install a draw straw? Do a search on this site for the airdog install I did a write up on it a few months ago!
Old Jun 10, 2010 | 11:01 AM
You have to have to install the draw straw.
Old Jun 10, 2010 | 09:19 PM
c0zgrove's Avatar
i did install the draw straw but the intank pump is still pumping as well
Old Jun 13, 2010 | 04:12 PM
c0zgrove's Avatar
ok got everything straight with the pump and installed a new manifold and a 62/13 turbo htt with the stainless housing but all i can boost is 25 psi i have a banks 6 gun with a smarty staked on that so shouldnt i be able to boost more anybody have any ideas oh and the turbo came with a boost fooler but i couldnt figure out where it went the turbo has a boost elbow on it too turned all the way in
Old Jun 13, 2010 | 09:46 PM
Is it a electronic boost fooler? PLUG IN?? If so not for your truck. But I'm a little confused your sig says 97 but you have a smarty with a banks 6 gun?? OK time to update your sig buddy!Assuming your a 03 and up put the boost fooler in and have fun!
Old Jun 13, 2010 | 10:14 PM
Billy D's Avatar
You said Raptor right?? I thought you didn't have to drop the tank with the Raptor, right?? So no draw straw right??
Old Jun 14, 2010 | 08:19 PM
c0zgrove's Avatar
yes i have an 03 as well haven't had a chance to update but my 12v is still my fav. the boost fooler is electronic but i cant find the plug to put it in and yes i did install the draw straw for the raptor pump
Old Jun 14, 2010 | 09:33 PM
The Banks is probably kicking in its safety protection.
