This May Not Count....
Old Jun 8, 2010 | 03:03 PM
theSLEEPER's Avatar
Default This May Not Count....
It's not REALLY a first-gen Cummins... it's a W150, but I'll be doing a diesel swap into it eventually. What do ya'll think?
Old Jun 8, 2010 | 08:47 PM
jasonfriedlin's Avatar
That'll be sweet!! You goin with the 4 cylinder or the 6?
Old Jun 8, 2010 | 09:26 PM
biged681985's Avatar
will be awsome truck once ya get it diesel powered. right now it just looks good
Old Jun 9, 2010 | 07:38 AM
theSLEEPER's Avatar
Definately a 6. I'm not sure though... I know the 4BT's can make good power too...
I'm only looking for around 450-500 quick-spooling hp with it. I'm thinking I'll go with either a VE or P-pumped 6 and a smallish set of compounds. I'm going to try to find a P-pumped of course, but if I can't, then I'll use the VE. I know where a full CR motor is, but I think it needs a rebuild...
Old Jun 9, 2010 | 12:06 PM
Your probably gonna have to beef up the front suspension with the 6. Its a heavy beast
Old Jun 9, 2010 | 12:15 PM
theSLEEPER's Avatar
Anyone know the weight on it? I would most likely swap over to SuperDuty axles.
Old Jun 9, 2010 | 12:22 PM
around 1150 iirc for just the motor. then the heavier trans, depending on which one u go with
Old Jun 9, 2010 | 12:51 PM
theSLEEPER's Avatar
OK... So about 600 more than the current motor... Hmm... I think the springs will be OK... But the D44 may not be....
Old Jun 9, 2010 | 12:57 PM
JD WOP's Avatar
Not sure I like the idea.
Old Jun 9, 2010 | 01:26 PM
theSLEEPER's Avatar
Which one JD?
