Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
shifting problem
Old Jun 8, 2010 | 05:47 AM
kaseydale's Avatar
Default shifting problem
My truck shifts fine sometimes, short ,fast shifts, then sometimes it does what I call flare between shifts. When it "flares" the engine will climb 300-500 rpm between shifts, pedal never moving. No box or programmer installed at the moment.Is this normal? If I hook to a trailer it might do it or maybe not but no noticable slipping when driving. No SES light. Could it be valve body or clutch packs or torque converter?
Old Jun 8, 2010 | 06:05 PM
D-MAXIN's Avatar
I know this will sound funny, but try swapping out the fuel filter.
Old Jun 8, 2010 | 10:13 PM
kaseydale's Avatar
I just changed filter out and still does it.
Old Jun 9, 2010 | 08:53 AM
D-MAXIN's Avatar
It could be in the converter then. Is your oil level good and the color/condition of the fluid look okay ?
Old Jun 9, 2010 | 05:01 PM
kaseydale's Avatar
Level, color, and smell all ok. Mainly noticable in 1st - 3rd gear.
Old Jun 9, 2010 | 06:04 PM
D-MAXIN's Avatar
Sounds like you will need to go for a test drive with a scanner & watch what is happening when it acts up.
I don't think it's slipping, (unless it's in the converter) otherwise you would be hitting limp mode. Maybe a solenoid slightly acting up ?? (Should be codes then)
Old Jun 13, 2010 | 01:24 PM
SgtKilroy's Avatar
Might be your NSBU switch?
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
Rabbitjbu
Jul 28, 2015 06:03 PM
SixSpeed
Jan 11, 2015 01:41 AM
Oct 14, 2014 03:30 PM
