ANY GUESSES
Old Jun 7, 2010 | 07:31 PM
spokes's Avatar
Default ANY GUESSES
my O3 6.o l is a real dog until the truck warms up to at least 170f? Any one had or have or heard of this problem?
Old Jun 7, 2010 | 08:08 PM
riddick01's Avatar
https://www.dieselbombers.com/ford-p...g-issues.htmlv
alot of 6.0 guys where havin that problem and thanks to the help of a couple good ppl at black cloud my problem was solved along with alot of other ppls. the link above it to that thread to see if ur problems line up and to see how it worked for everyone that tried it
me i swear by the stuff
Old Jun 7, 2010 | 08:59 PM
Mdub707's Avatar
Gonna need a lot more info to help diagnose. Is it stock? How many miles on it? If it's not stock, what mods? Is it throwing any codes? Does it smoke at all and what color smoke if it does? What is the truck used for and how often is it used?
Old Jun 8, 2010 | 08:35 PM
spokes's Avatar
I have 2 new heads,arp studs,new oil cooler, egr delete,straight pipe.Running edge juice platinum with attitude. Smokey start ( white, blue ) Use the truck every day( 50km ) on the highway. Throwing codes P006A, P0401, P0671, P0672, P0676, V0105
Old Jun 8, 2010 | 10:28 PM
Karls03's Avatar
As far as the cold sluggishness goes, the Edge won't unlock full power until the engine is at operating temp. I know, I have the same unit. It's written somewhere in the owner's manual, it's one of their safety features.
The biggest improvement I saw in sluggish performance was a Gillette Diesel pressure spring. SOMETIMES I have a little blue on the first crank of the day and I usually don't throw codes, well, none when all of my fuses are in good working order....
Old Jun 8, 2010 | 11:31 PM
FRIDAY88's Avatar
looks to me like you have glow plug issues and mabey some sticky spool vavles try some REV X Oil addative Works wonders buddy
Old Jun 9, 2010 | 09:28 AM
MUDSTROKIN''s Avatar
Cold engine protection ont he edge keeps you from getting full fuel until the engine temp reaches 175* i believe it is.... If it's just a little under powered until then i wouldn't worry about it. But if it's bucking and jerking and missing then you have a problem.
Old Jun 9, 2010 | 12:40 PM
Mdub707's Avatar
P006A isn't a real code... needs 4 numbers, no letters
P0401 is an EGR code, which you will have until you get an SCT. Usually 03-04 trucks don't throw a code, but never say never I guess...
P0671 is cylinder 1 glow plug circuit
P0672 is cylinder 2 glow plug circuit
P0676 is cylinder 6 glow plug circuit
This leads me to believe your glow plug harness might be chaffed, go over it with a fine tooth comb, and if there is ANY chaffing, replace it. This would also be why you have rough starts and some smoke on start up, since you're not going to burn any fuel in these cylinders very well until warmed up. It's also very likely it's the glow plug control module since you have multiple bad at once. These glow plugs usually dont go bad often.
V0105 doesn't seem to be a real code, which is what happens when reading with the Edge products, I've seen bullydog do it too, where it has different letters that don't mean anything. When searching for this I see almost everyone saying they get this code when they read codes with their edge. I believe the code is supposed to be U0105, not V. It is a loss of communication with the FICM. Check your connections and make sure everything is tight.
My buddy had an 04 6.0 with a bullydog triple dog. He always had a rough running one, and I told him to pull codes on it. The only codes he kept getting were some Uxxxx code which was a loss of communication with window motor. When he finally got an SCT we read the codes with that and sure enough that same code then came up as a Pxxxx and it was a glow plug issue, which is why it always started rough. Since then I haven't really trusted the funny codes that some of the "programmers" read.
Old Jun 9, 2010 | 06:02 PM
DoneDunIt's Avatar
It is a real Code
2 new fault codes P132B and P006A
Issues with turbocharger, MAF sensor, MAP
sensor/hose, intake leaks, exhaust leaks, etc.
Might have a non stock Air Filter
Old Jun 9, 2010 | 09:39 PM
Mdub707's Avatar
Originally Posted by DoneDunIt
It is a real Code
Just because the programmer shows it, doesn't mean it's a real code. Show me exactly what those codes mean then......
I've NEVER seen codes with letters on the end. I'm interested to see what they are.
Are you friends with spokes or what's the deal?
