check engine light??
Old Jun 6, 2010 | 10:18 PM
jake 94's Avatar
Default check engine light??
so i unplugged my bosst fooler to plug the edge in and i plugged the edge in but the boost wasnt reading and now my check engine light is on. What the hell happened?
Old Jun 6, 2010 | 10:20 PM
01quadcab's Avatar
what did you unplug? edge reads boost from map sensor. You need to plug the map sensor back in.
Old Jun 6, 2010 | 10:22 PM
jake 94's Avatar
i did plug it back in and still i got nothing but the check engine light
Old Jun 6, 2010 | 10:23 PM
RAW's Avatar
RAW
Is the edge harness directly plugged into the MAP sensor? Another fooler in the circuit may cause the problem. If you have just the edge harness and the factory harness plugged in, it may just need a battery disconnect and sit for a bit.
Old Jun 6, 2010 | 10:25 PM
jake 94's Avatar
i had the edge plugged in and that made the check engine light come on and it wasnt reading boost so i plugged my fooler back in and still my check engine light is on but the light on the boost fooler is on
Old Jun 6, 2010 | 10:30 PM
RAW's Avatar
RAW
I assume the factory harness is plugged in as well? If so, there could be an issue with the Edge itself.
Old Jun 6, 2010 | 10:31 PM
jake 94's Avatar
well all i unlugged was the boost fooler then i plugged the edge in and it did this
Old Jun 6, 2010 | 10:33 PM
RAW's Avatar
RAW
With my Edge I have the Edge harness plugged into the MAP sensor, and the factory boost harness plugged into the Edge harness. It's all working for me, no boost fooler.
Old Jun 6, 2010 | 10:34 PM
jake 94's Avatar
well then there is something wrong. because i have no boost raedings fron the edge when its plugged in
Old Jun 6, 2010 | 10:39 PM
01quadcab's Avatar
Sounds like your factory plug for your map sensor is not plugged in. mine would not build boost till it was...
