6.0 oil in collant
Old Jun 6, 2010 | 05:24 PM
rebeltaz's Avatar
Default 6.0 oil in collant
Bought 2004 f-350 6.0 new head gasket was put on and now my collant holder is filling up with motor oil no loss of power just a smell of oil @ antifreeze blowing back in cab every now and then (whats going on) i dont know crap about diesels new to diesel engines. thanks for info.
Old Jun 8, 2010 | 01:41 PM
lubbockguy1979's Avatar
You have a blown oil cooler. Your oil cooler was stopped up limiting flow and now has ruptured. This elevated the coolant temp which boiled/ puked causing the head gasket failure. This is why I and a lot of others reccomend a new oil cooler and either a new egr cooler or egr delete when you do head gaskets. Do your self a favor and get a new hpop screen from ford. The new stainless screens are improved. Also when you replace the oil cooler and the egr get a coolant filter to try to reduce the chance of having the oil cooler plug up again. If you want to stay on top of things get a set of gauges either digital or analog that will tell you coolant temps and oil temps. They should be 15* or less differential in temps after the truck is at operating temps
Old Jun 8, 2010 | 04:24 PM
rebeltaz's Avatar
thanks alot for the info truck is in garage now ill be sure to make sure all this done to it.
"thanks"
soco
Jul 27, 2015 06:06 PM
scubasteve12
Mar 29, 2015 09:39 PM
emilio2496
8
Jan 13, 2015 05:03 PM
ash23k
Dec 30, 2014 08:31 PM
iam1746regan
Dec 21, 2014 05:06 PM
