12 valve
Old Jun 5, 2010 | 03:26 PM
HAYMAFIA's Avatar
Default 12 valve
are the pistons in the 91 12 valve and a 95 12 valve the same. reason being i have a 91 motor and want to put the 215 stix in it. will it work
Old Jun 5, 2010 | 04:45 PM
12vcummins96's Avatar
the pistons are the same yes
Old Jun 5, 2010 | 04:50 PM
HAYMAFIA's Avatar
so would it be better to swap the head too since the 91 is not intercooled.
Old Jun 5, 2010 | 08:04 PM
skyjacked84's Avatar
use boat ones. the dome is bigger so you can do more timming
Old Jun 6, 2010 | 01:47 PM
94 12valve's Avatar
if the 91 is non initercooled than the pistons are different than the 95's
also the head on the non intercooled 91 will need 9mm injector tips
Old Jun 6, 2010 | 08:05 PM
FastCR's Avatar
Correct from what I know, the non IC pistons and head design are different. you could check on compD to see if theres any gains to be had using the non IC'd pistons.
Old Jun 6, 2010 | 11:21 PM
HAYMAFIA's Avatar
may just try and build the 95 engine back up
RA113024
Mar 13, 2016 07:42 PM
jeremiah1
Jul 21, 2015 06:35 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
behrendt1061
Dec 4, 2014 05:49 PM
