My Vents dont switch
Old Jun 4, 2010 | 12:03 PM
hiboy_76's Avatar
Default My Vents dont switch
I thought i saw a thread on here on how to fix the vacume controller to switch the vents. Could anybody tell me hor i can fix this? Thanks.
Old Jun 4, 2010 | 01:07 PM
ArizonaRedneck's Avatar
i ended up changing my main heater control switch out to get mine to work
Old Jun 4, 2010 | 01:40 PM
blkjack's Avatar
As long as you have vacuum getting to the controller then AZ redneck is right u have to change the control head
Old Jun 4, 2010 | 05:02 PM
hiboy_76's Avatar
ok thanks guys.
How hard is it to change?
Old Jun 4, 2010 | 05:17 PM
tltruckparts's Avatar
not hard at all. take off the dash bezel and its just a couple screws
Old Jun 4, 2010 | 09:13 PM
Begle1's Avatar
There are three vacuum actuators that control the vents. One selects between drawing air in through the floor inlet on the passanger side of the vehicle or drawing air from under the windshield. This one is behind the glovebox facing to the right. One selects between flowing air out of the floor vents or the head vents. This one is behind the glove box facing to the left. The third turns defogger vents on or off. This one is down to the right of the driver's feet. They're all easy to get to, pull the vacuum hoses off of and see if they're getting vacuum when they're supposed to be.
If they are getting the right vacuum but not moving correctly, it's a problem with the actuator, either too much crude on the pushrod or a leaky diaphragm. If they aren't getting the right vacuum it's either a problem with the switch or the leaky lines. After 20 years, the lines may very well be cracking like Jesse Jackson in Harlem.
I took my stock push-button vacuum controller module out and replaced it with three switches on the dash and five solenoid valves behind the glove box.
cumminspwr11
12
Oct 17, 2021 03:50 AM
rstrange1996
Sep 22, 2015 01:25 PM
Ryans71
Diesel Engine Conversions
Dec 24, 2014 08:47 AM
Cody Cain
Dec 22, 2014 01:27 PM
IslanderXJ
Dec 17, 2014 04:14 PM
