injectors help
Old Jun 3, 2010 | 03:16 PM
az coil roller's Avatar
Default injectors help
can someone tell me how the remove the injectors, a write up work be grate
thanks justin
Old Jun 3, 2010 | 04:25 PM
oglejust's Avatar
unscrew the lines, i remove the hold-downs closest to the injector so u can get the lines out of the way. remove the return line that connects the injectors together. remove the injector hold down nut. screw a lug nut (yes a lug nut off ur truck) onto the injector, grab the lugnut with a pair of vice grips and pull it out. if its bein stubborn then take a piece of 1in pvc pipe and cut it to where when u slide it over the injector that a few threads show then screw the lug nut down to pull it out.
Old Jun 3, 2010 | 04:56 PM
cumminspwr11's Avatar
or you can weld a nut onto the back of that lug nut and use a slide hammer, i use a 4" or so bolt for the back two and a 8 or 10" one for the rest
Old Jun 3, 2010 | 11:10 PM
dan33klein's Avatar
the injector threads are 14mm x 1.50
therefore you need to go BUY a lugnut for a ricer...
our lugnuts a standard thread 9/18-18 i believe,
trust me, i used one off my truck and almost ruined the threads on the injectors ouch
9/16-18*****
Old Jun 3, 2010 | 11:21 PM
Thanks guys
Old Jun 3, 2010 | 11:39 PM
94 12valve's Avatar
9/16-18*****
my lug nuts thread right on the injectors
Old Jun 4, 2010 | 07:18 AM
dan33klein's Avatar
i threaded mine on and went to keep tightening it to suck the injectors out and it gave away and almost took all the threades with it. went the the storee bought a 14mm 1.5 and it threaded on tightly and worked great
Renteria1217
19
Oct 13, 2015 01:36 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
