In tank Pump?
Old Jun 3, 2010 | 08:36 AM
98dodgecummins's Avatar
Default In tank Pump?
is it possible to have a fass ddrp lift pump plus a in tank pump? how do you check if you have a in tank pump? Maybe thats why my fuel pressure is so high?
Old Jun 3, 2010 | 08:50 AM
What is your pressure?
It could have an intank pump. How long have you owned the truck?
Old Jun 3, 2010 | 09:36 AM
cumminspwrram59's Avatar
to my knowledge they dont have a pump in the tank. the guy i got my truck from had to replace the lift pump the day i got my truck. he called dodge and they swore it had a in tank pump but he dropped the tank it there wasnt one.
Old Jun 3, 2010 | 07:06 PM
RAW's Avatar
RAW
Check the left fender for a relay. From it there would be 2 wires running to the tank, and 2 more running to the engine harness for the lift pump power. The relay in my truck is mounted near the left hood hinge.
Old Jun 4, 2010 | 11:32 AM
well the reason im asking is because my fuel pressure is 20 to 22 at idle.
ok i was looking under neath and i looked on top of the tank where the fuel lines go into the tank and on top you have your two fuel lines and the right beside it i seen some type of sensor right beside them and the wiring was going from the tank all the way to the motor? Is that just a sensor for the fuel level or what?
ok just looked some more there is some type of relay theat plugs in on top of the tank and it has 4 wires running out of it going all the way to the motor?
need some answers?
Last edited by 98dodgecummins; Jun 4, 2010 at 11:32 AM. Reason: Automerged Doublepost
Old Jun 4, 2010 | 11:51 AM
01quadcab's Avatar
does your truck have a factory lift pump on the block? if that is gone then your truck has an in tank pump and your better off removing it and adding a sump to the system. You will already have the tank out.
Old Jun 4, 2010 | 11:53 AM
no i have a fass ddrp lift pump thats mounted to the block.
Old Jun 4, 2010 | 02:27 PM
01quadcab's Avatar
is this how you bought the truck? seems like you have a very good possibility that it does have an in tank pump to get that much pressure out of a ddrp. We put a different spring in mine to make my fass make 20 and it does it idle through wot
Old Jun 4, 2010 | 03:45 PM
i dont like my fuel pressure at 20 because when it gets their it starts having a little miss to it.
if i didnt want maybe if i have a in tank pump could i unplug the relay so the in tank pump wouldnt work if that is what it is ?
Last edited by 98dodgecummins; Jun 4, 2010 at 03:45 PM. Reason: Automerged Doublepost
Old Jun 4, 2010 | 06:43 PM
01quadcab's Avatar
your ddrp will not be able to draw fuel through the in tank pump. your going to have to drop the tank and add a draw straw
