boost elbows?
Old Jun 2, 2010 | 05:01 PM
mb5n537's Avatar
Default boost elbows?
can i make a boost elbow myself or just plug it off and if so what do i need and how hard is it? never messed with my turbo much only turbos im used to dont have waste gates. and if not how much is one and where do get it?
Old Jun 2, 2010 | 05:33 PM
Your truck has the HY35 turbo which does not use a boost elbow. You can your a turn buckle to clamp the wastegate closed.
Old Jun 2, 2010 | 09:13 PM
mb5n537's Avatar
a turn buckle? like a hose clamp or something? and will it help any?
Old Jun 3, 2010 | 06:18 PM
RAW's Avatar
RAW
When I had my HY35 I removed the wastegate actuator, and screwed a machine screw into the metal tube. Then I took the tube with the screw in it to a bench grinder and ground the head of the screw down to be the same O.D. of the tube. Went from 18 PSI boost, to 29 PSI. Kept the EGT's way lower as well.
Old Jun 3, 2010 | 06:46 PM
wyodiesel92's Avatar
Won't pinching off the waste gate cause problems?
Old Jun 3, 2010 | 07:09 PM
RAW's Avatar
RAW
Some say it does, and there is a chance of over speeding the turbo. I ran mine pinched for 6 months, with no problems at all. When I removed it to put my HX35 on, there was no damage, no play, and still works awesome.
Old Jun 3, 2010 | 09:50 PM
mb5n537's Avatar
where did you get your hx35? and how much was it if you dont mind me asking?
Old Jun 4, 2010 | 12:01 AM
Uncle Bubba's Avatar
Just make a post in the parts wanted section of this site to see if anybody has one they want to sell. Always guy's buyin bigger turbo's and wantin to sell the stock ones.
Old Jun 6, 2010 | 04:11 PM
Fiveseven's Avatar
Would the boost elbow be something I can use on my truck ?
Old Jun 6, 2010 | 04:40 PM
RAW's Avatar
RAW
Should, I imagine you have the stock HX35 on your engine. It will help if you do.
Un4givn
10
Apr 27, 2015 01:58 AM
chaoticape
Jan 4, 2015 05:35 PM
ash23k
Dec 30, 2014 08:31 PM
Crews8r
Dec 21, 2014 07:35 AM
joshkhouse80
Nov 21, 2014 01:17 AM
