start up problem! need help!
Old Jun 2, 2010 | 12:20 PM
goobs's Avatar
Default start up problem! need help!
ok here's my delima. when i turn the key on to let the glo plugs come on they do and the batt. voltage drops to zero! then the light goes off and the volt gauge goes up 10-12v
and then i go to start the truck and it barely turns over and i have to pump the pedal to get it to start.
i check the batts and the altenator they're fine and working.
so im pretty sure its in the glo plug sys. some where.
if someone could help that'd be great. i have a gm electrical wiring book that's 4" thick and service manual but i need a place to start.
Old Jun 5, 2010 | 09:53 PM
goobs's Avatar
anybody? why is it when the glo plugs are on the batteries drain?
Old Jun 5, 2010 | 10:08 PM
2MuchJunk's Avatar
I haven't forgot about your problem yet but I can't say I have a good answer for you. My number one guess would be your batteries but you tested them as good. Check all your connections on the bats glow plug solenoid and the alt. If none of them are the problem then the next place I would check is the glow plugs there self.
Old Jun 5, 2010 | 11:14 PM
goobs's Avatar
thanks. i've checked most of the major connections like the batts, alt, etc. just havent had time to finish the little ones. im assuming it is the glow plugs since they're original on a 151,000 mile truck.
burndiesel
10
Feb 7, 2023 01:15 AM
ish1521
Aug 26, 2015 08:42 PM
thurobred1320
May 5, 2015 09:26 PM
96bigD
9
Apr 4, 2015 04:42 AM
ronstop
Feb 26, 2015 09:48 AM
