Injector Swap
Old Jun 2, 2010 | 11:51 AM
Thekingrulz69's Avatar
Question Injector Swap
So there is a trash truck at a near by junkyard that has a '93 cummins in it and i wanted to take the injectors out of there and put em in my 5.9 cummins, which is also a '93. Will they fit? I cant remember the size of the engine, but here are some numbers that might be useful.
Model: L10-260
Engine Family: 343E
Not so useful numbers?
Engine Number: 34697291
SO number: 12483
Reference: 869381
(Those numbers came off of the trash truck, not mine)
Old Jun 2, 2010 | 12:19 PM
aarons91cummins's Avatar
Check and see if the donor trucks is intercooled like yours. If it is they should work.
If your truck is really a 93 it's intercooled. Make sure the donor is also intercooled. If it is then they should work.
Last edited by aarons91cummins; Jun 2, 2010 at 12:19 PM. Reason: Automerged Doublepost
Old Jun 2, 2010 | 12:27 PM
Thanks! I'll give it a try.
Old Jun 2, 2010 | 04:06 PM
RSWORDS's Avatar
Are you sure its a 5.9? Also I would think a trash truck would have ALOT of miles on it. What benefit are you looking to get from these?
Old Jun 2, 2010 | 08:11 PM
Richie O's Avatar
I would also check on which injection pump is on it. It may have a P Pump.
