TRIPPLE STACKED?
Old Jun 1, 2010 | 07:51 PM
LawnScum's Avatar
Default TRIPPLE STACKED?
i have the quadzilla ADR and smarty stack. i was wondering if theres anyway i can put the TS power module on also? a friends selling his and was thinking about buying it. thanks
Old Jun 1, 2010 | 07:58 PM
turbo20psi's Avatar
This isnt burger king.Stacking all that sounds like a timing problem in the long run.That ADR will fuel enough with 150s.
Old Jun 1, 2010 | 09:12 PM
AF1CUMMINS's Avatar
Old Jun 1, 2010 | 09:23 PM
turbo20psi's Avatar
I like popcorn.mmm
Old Jun 1, 2010 | 09:59 PM
bobcat67's Avatar
yeah i'd advise against it 2 things is more than enough fuel, unless you have a completely built race motor or something i doubt the stock engine will handle that kind of timing
Old Jun 1, 2010 | 11:33 PM
01quadcab's Avatar
the vp is only going to take so much before you over time it. One day I might try the quad adrenaline see if it can top my drag comp that just put me into the 11's.
Old Jun 2, 2010 | 05:47 AM
LawnScum's Avatar
if the comp is just like the edge JWA. then the quadzilla will give you some more h.p. my quad with the tourqe tune is insane!! itl pull hard till about 2500 then it will pull even harder from there!
Old Jun 2, 2010 | 06:51 AM
Jazz's Avatar
I think with what you have already your not going to get anything more out of stacking another programmer. I'm running the adrenaline and smarty stack also with 200+hp injectors and don't think I could get any more out of this pump
Old Jun 2, 2010 | 06:54 AM
Diesel Dummy's Avatar
The adrenaline already maxes the pump, the next step is a redline to get it to fuel to 4K or the new 4K adrenaline, these pumps arent like a p-pump, you want more fuel change to the bigger vps or p-pump it.
