front axle disasembly
Old Jun 1, 2010 | 10:04 AM
dan33klein's Avatar
Default front axle disasembly
hey guys, im doing my ball joints and i cant even get past the rotor
what size is the axle nut?
and whats the best way to get the both the rotor and hub off?
ive already sprayed it for the last 3 days with kroil.
i used a big puller, and already destroyed the rotor with a sledge hammer trying to get it off, it still wont budge(decided i was gunna replace rotors and pads while im in there)
any tips you guys have will help asap thanks
Old Jun 1, 2010 | 10:58 AM
85_305's Avatar
Being Evaluated
I'll sell you a HUMMER axle
It wont break that way.
Old Jun 1, 2010 | 12:27 PM
oglejust's Avatar
the rotor comes off the back of the axle.. u need to take the 4 bolts out of the back that holds the wheel bearing on then take 1 of the bolts to a hardware place and get 1 thats a bit longer, screw the longer 1 in and hit the bolt with a sledge hammer and the whole assembly (rotor, wheel bearing, and axle shaft) will come out. i take the spindle nut off after its all apart but u dnt have 2 if all ur doin is ball joints
if u dont understand that pm me and ill send u my phone number
Old Jun 1, 2010 | 12:30 PM
yeah RIGHT.....
Old Jun 1, 2010 | 12:55 PM
85_305's Avatar
Being Evaluated
come on now! 8.6" HUMMER axles > dodge axles :P
Old Jun 1, 2010 | 02:12 PM
monster12valve's Avatar
are u comparing a dana 60 to a IFS piece of trash gmt-355 H3 hummer?
Old Jun 1, 2010 | 04:19 PM
Its been awhile - but there are 4 bolts (14 or 15 mm socket I believe) that hold the rotor on the hub. Pull the rotor and hub off as an assembly. Then seperate the rotor from the hub.
Old Jun 1, 2010 | 06:14 PM
85_305's Avatar
Being Evaluated
Dana/Spicer ftmfw!! Sorry, Hummer's got one too!
Old Jun 1, 2010 | 07:25 PM
dan33klein's Avatar
you pry drink martinins instead of whiskey when you pull up to the bar in that mom vehicle
Old Jun 1, 2010 | 07:41 PM
cumminspwr11's Avatar
did you get that off?
