needing turbo help!!!!
Old May 31, 2010 | 04:31 PM
rgnagy74's Avatar
Default needing turbo help!!!!
Well I was getting on the on-ramp and heard a loud POP then lost power! Lots of white smoke out the tail pipe...turbo blew! I took off the elbow to my bhaf and saw a pile of turbo guts !!!! Well i'm looking for some advice on what to replace it with and would like to keep the price resonable. Im not looking for a racer and don't pull anything heavy but I do pull a 4500lb boat alot! Here is what I have 2003 2500 HO 4x4 quad cab 48re with upgraded converter and shift kit, bully dog programer run on extrem with added low end power. 4" exhaust and a ******* whistler air cleaner. If my injectors fail I would like to upgrade them but hopefully not soon. Im looking for a turbo that will work now and in the future with some larger injectors. Thanks
Old May 31, 2010 | 04:50 PM
Phat Shaft 62 or 64.
Old May 31, 2010 | 05:37 PM
07redsled's Avatar
htt 64/71/13 ss talk to anthony at htt
Old May 31, 2010 | 06:25 PM
rgnagy74's Avatar
what are the pros and cons between a 62 or 64 i also see they are sold with a 12cm or 14 cm exhaust opening???
Old May 31, 2010 | 06:46 PM
HTT offers a SS 13cm housing. The 64 will flow more air but will take a bit more to spool up. What size injectors are you looking at getting down the road?
Old May 31, 2010 | 07:30 PM
rgnagy74's Avatar
Probably 50-90 hp nothing major??? Whats a good time to call you Lucas?
Old May 31, 2010 | 08:01 PM
HighPlainsDrifter's Avatar
if you need a cheap turbo fast the HE351 from the 04.5 and up trucks are cheap and offer a small upgrade since they are a 60mm and the 03 have a 57mm, until you get a 62 or 64.
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
