06 CTD NO GO
Old May 31, 2010 | 07:26 PM
Matt5005's Avatar
Default 06 CTD NO GO
I have a 06 CTD no mods except air intake and exhaust. I ran my truck all day here and there, went to park and and decided I need to move so the wife can get in went to start it nothing cranked and cranked and cranked no start tryed it twice. I let it sit for like 10 min started fine. I tryed it 5 more times and started fine. I didn't drive it anywhere just tryed to start it. about 1 out of 20 times starting it seems to take 10 times longer to start and normal. Any ideas, I was thinkin lift pump
anyone?
Old May 31, 2010 | 07:40 PM
dangerous1965's Avatar
Your gonna have to get some guages! Check your rail pressure. How many miles on it?
Old May 31, 2010 | 07:41 PM
UntrainedEye's Avatar
How many miles, when was the fuel filter last changed, filter bowl drained of water/contaminates, any codes when you cycle the key 3 times, the CEL on??
Old May 31, 2010 | 07:48 PM
Matt5005's Avatar
less than 3000 mi since fuel filter change bowl drained. 84,000 mile on truck
no codes that I know of, smarty on the way to check. what do you mean cycle the key 3 times and what is the CEL?
Thanks for the help any more imput will help
Old May 31, 2010 | 07:50 PM
CEL= Check Engine Light
You cycle the key three times, and it'll bring up some numbers starting with a P, U, or C.
But because you got a Smarty, don't need to worry about it.
Old Jun 1, 2010 | 04:54 PM
Matt5005's Avatar
Thanks, I am using my bro's smarty to read codes, just got the truck and haven't had the time or $$$ to put into it yet but if it is a lift pump a air dog and set of gauges are on the way
Code reads Invalid Skim Key. No idea
anyone know what a Invalid Skim Key is???
Old Jun 1, 2010 | 05:43 PM
CreeperSleeper's Avatar
IIRC, the "Invalid skim key" code is part of the security system. It will throw that code if you shut the truck off, then restart it without taking the key out of the ignition. I don't think that is your problem. If it is, something is amiss in your security system.
Old Jun 1, 2010 | 07:38 PM
Matt5005's Avatar
I cleared the code, and the truck seems to run fine. What do you think my problem is? I am kinda new to the CTD so any help would be great. Thanks
Old Jun 1, 2010 | 09:27 PM
I got the same code once. Changed the battery in both my key fobs, and it never came back.
Old Jun 1, 2010 | 09:54 PM
bobcat67's Avatar
yeah in the 06's the key has to be in the ignition and the battery has to have power in the key fob because it sends a signal to something in the ignition system so if the battery is weak it won't start the truck or it'll start and run for a few seconds and then shut off, I'd switch the batteries in the fob then go from there
smokee
Mar 21, 2015 10:09 PM
smokee
Feb 14, 2015 12:09 PM
smokee
Feb 7, 2015 01:27 AM
streetrod
Price Quote - Request A Price
Nov 17, 2014 09:50 PM
5.9Cumminsturbodiesel
9
Nov 6, 2014 06:08 PM
