good setup?
Old May 31, 2010 | 10:25 AM
marylandusmc's Avatar
Default good setup?
will a tst pm3 and 100hp injectors be a good setup? i have a edge comp now and i am very disapointed in it. will i need a aftermarket turbo? thanks for info
Old May 31, 2010 | 11:06 AM
01quadcab's Avatar
do you only have the comp and no injectors? The comp box makes good power. I just put down 665 sat night and went 11.91 with a drag comp compounds and a some smoky injectors. so vp
Old May 31, 2010 | 12:48 PM
i just got comp but i keep havin vp issues. i got a airdog 100 and good tranny.
Old May 31, 2010 | 02:23 PM
What type of VP issues?
Old May 31, 2010 | 03:32 PM
every year the pump seems to fail. and while its on through out the year the performance falls. i got the airdog on there and pressure stays at about 17-15 psi. i am not sure what else could be causing the issue other than the comp box. i would have bought a different box when i got it but at the time i thought it was my best option. do u have any suggestions? thanks
Old May 31, 2010 | 03:52 PM
2141pete's Avatar
I have ran pretty much all of them for a 24v and the Adrenaline was my favorite hands down. You will hear good and bad about Edge, TST, and Quad but that is just my experience.
Old May 31, 2010 | 04:38 PM
i wish i woulda bout a damn 98 . they are priced about the same. is the adrenaline difficult to update?
Old May 31, 2010 | 04:45 PM
If the Comp is causing the issue then Id recommend sending it into Edge and letting them test it to make sure its working properly.
Luke
Old May 31, 2010 | 04:56 PM
man i think damn ch-53s are easier to make sense of than these damn pumps the comp seems to hit at a funny rpm as well. i remember it being lower when i 1st got it. havnt driven it for a while but will in the next couple weeks. will the quadzilla come on at lower rpms than the comp?
Old May 31, 2010 | 05:02 PM
The Adrenaline comes on a bit lower but to me its not as smooth as the Comp. I sold my Adrenaline and went with the Edge Juice with Attitude.
Luke
