rough and missing at idle.
Old May 28, 2010 | 07:04 PM
dragander's Avatar
Default rough and missing at idle.
my 05 has a rough idle and is missing and can't seem to track down the problem. Adusjted the valves which made the motor quieter, but still have a miss. no codes, no fuel in oil, no blow bye. acts as if its loaded up and after it gets off idle seems to run ok. Replaced injectors not that long ago from DDP. Ideas???
Old May 28, 2010 | 07:07 PM
How does it run if you remove the Bully Dog?
Luke
Old May 28, 2010 | 07:08 PM
dragander's Avatar
runs the same... was the first thing i did
Old May 28, 2010 | 10:15 PM
dangerous1965's Avatar
You may have lost an injector only way to know is take them out and have them tested
Old May 28, 2010 | 10:41 PM
dragander's Avatar
i checked rail preasure and all is good. Talked to a place in town that has a test stand. I'm wondering if i have a bad valve.
Old May 29, 2010 | 12:29 AM
jara2006's Avatar
Default 48RE Bands
hey gays from houston area.Any body knows a reliable trans mechanic or shop
Old May 30, 2010 | 12:37 PM
Jara2006
Thanks for the laugh!!!
If you have a bad valve you would know it!!
Old May 30, 2010 | 02:08 PM
dragander's Avatar
Anybody know what the ohms readings are on the injectors? maybe i can track it down that way.
jbxyz
Chevy/GMC Duramax 01-04 LB7
10
Apr 24, 2015 07:19 PM
firefighteremt
Feb 2, 2015 01:59 PM
Snoobly
Dec 11, 2014 11:59 AM
Js1215
Nov 8, 2014 12:25 AM
99stackedpowerstroke
Oct 8, 2014 07:06 PM
