beef up my auto trans
I have a 91 1/2 D350 dodge dully 2wd its has an auto trans with od, i plan on makin some more power with the truck. i got the trans out to be fixed i would like to put some good gear in it to hold up , any ideas ?
How deep are your pockets and how fast do you want to go?
PATC 46RE 47RE 48RE Transmissions, Performance Transmission A518, 518
TCS Products - Products
Sun Coast Converters Diesel Transmissions, Fort Walton Beach FL
Chrysler RWD Transmissions A518 (46RE), A618 (47RE, 48RE) Makco Transmission Parts
. . .. Just to name a few parts vendors.
First on the list should probably be a big mean shift kit, as agressive as your willing to live with, eliminate as much of that sloppy overlap between gears as possible, this makes a huge difference in longevity
A good, aftermarket converter should probably be next, i personally dont run one(only due to a lack of funding) but from what ive heard, everyone that is using one wouldnt have it any other way
I don't know how much power your talking about putting to the thing, but one of these transmissions, even just rebuilt to stock spec's will take a very impressive amount of abuse before something comes undone
with what you have dont to your truck you would have a jammer over how much better your truck will pull!!!! you wont believe it till you try it!!!!
i would do the torque converter first!! doesnt matter how beefy you trans is built if your sloppy converter is pushing super heated fluid through everything else in there its not gonna help things out!!!!!
i want a manual valve body and a ratchet shifter!!!
dirty it sounds like you really need a good torque converter!! haha
Like everything, they have there weaknesses. The torque converter being the #1, shift kit is a good improvement, then they do have to problem with the backflow when it is off which drains fluid from the torque converter, and then for the guys that haul real heavy loads then upgraded cooling system would be a good idea UNLESS, you are one of the lucky ones that has the auxiliary cooler under the bedside then you would have to worry about temp all that much. But the cooling is that same with any OE setup with any truck if your pushing it to it's max often.
Maintained correctly, they are good reliable transmissions (with reasonable power).
