2005 Dodge 48RE
Old May 27, 2010 | 03:46 PM
colt45_usmc's Avatar
Default 2005 Dodge 48RE
Hey everyone Ive got a 2005 dodge 3500 4X4 48RE with around 140,000 miles and I am having really bad vibration when Ive got the cruise control set and im coming off a hill or even driving around town and i let off of the gas petal. Once I hit 70 mph and higher it starts vibrating. I assumed it was U joints but all appear to be fine. I replaced a U joint in my front drive shaft and found that the centrifical joint, the little needle bearing in between your front two U joints was completely trashed. So I still have the front dirve shaft off, since the dodge dealership told me im going to have to buy a whole new front drive shaft. Any ideas where the vibration could be coming from? tranny, rearend, drive line? Thanks, Colt
Old May 27, 2010 | 05:17 PM
CreeperSleeper's Avatar
I would guess rear driveshaft because of it vibrating when you let off on the throttle...
Old May 27, 2010 | 07:34 PM
lunk's Avatar
ya dodge just replaced my twice (u-joints) then had to rebalance the drive shaft my vibrated bad now i have a slight vibration at take off but harldly noticable so it will go back before the warranty"s up. mines an 04
Old Jun 1, 2010 | 04:17 PM
i got to thinking about it and all of my problems started when i removed my front drive shaft to replace u-joints and reinstalled the front driveline. is the front drive shaft balanced as well? could this hopefully be my problem?
Old Jun 1, 2010 | 05:47 PM
Yes! The front shaft needs to be balanced and in phase. (If it's a 2 piece shaft.)
Old Jun 2, 2010 | 10:48 PM
so basically put it back on and keep turning it until the vibration quits? or am i going to have to take it to the shop and get it done?
Old Jun 3, 2010 | 12:15 PM
mxtuner1's Avatar
Make sure you mark it and keep rotating 90 degrees. If after three strikes it doesn't get any better you have a bent drivershaft. Replacement time.
Old Jun 3, 2010 | 11:53 PM
Ok thanks yall for all the help!! I really appreciate it
mike531
Aug 22, 2015 04:25 PM
rodbuilder
Jun 28, 2015 08:23 AM
May 7, 2015 02:50 PM
Iron Man
Nov 19, 2014 06:12 PM
