Head Stud Question
Old May 26, 2010 | 01:33 PM
spetersen502's Avatar
Default Head Stud Question
When your changing from head bolts to studs is it the same procedure and torque specs
Old May 26, 2010 | 10:44 PM
Mdub707's Avatar
No. The studs will come with new directions. The stock stuff uses torque numbers until a certain point, then switches to torque angles, meaning turn the breaker bar 90 degrees, then next bolt. The studs use straight torque specs. FOLLOW THE RECOMMENDED TORQUE SPECS OF THE STUD MANUFACTURER. Some people seem to think it's a good idea to go above that... and well... it's not.
Old May 27, 2010 | 09:11 AM
riddick01's Avatar
they tell u how tight to torque it for a reason. if u look at arp im sure they tested all different levels of torque and found whatever level they use is best.
now i am sure that u have a little bit of play in the numbers just in case u give it one click more than it needs but still...its like hunting...missin the dot by a little can still be a kill shot but miss the dot by to much and ur gunna be trackin...
Old May 27, 2010 | 03:24 PM
Mdub707's Avatar
Trust me, at 245 ft/lbs for the old style lube, you're not going to accidentally go past where you need to be. You will have big arms by the time you're done.
ARP has a new lube out though that lowers the highest torque to 210 ft/lbs, and is much more consistent than the old stuff or anything else you can get. If you use the new lube and go to 245, you will yield the studs to the point they might snap.
gd1996
For Sale
May 15, 2015 09:42 AM
TheMacster
5.9L 24V Performance
Apr 14, 2015 07:01 PM
klein444
6.2L & 6.5L Performance
Apr 14, 2015 09:04 AM
Adam65
Jan 9, 2015 11:50 PM
twinturbo12v
10
Dec 8, 2014 07:58 PM
