Air Dog Visit - AIR DOG
air dog questions
Old May 26, 2010 | 09:32 AM
biged681985's Avatar
Default air dog questions
when i put the air dog on my truck, i had a problem with fuel coming out of the old supply line to the stock lift pump. it more or less syphoned the tank when it was full, and had to put vise gribs on the line, and i ended up making a plug right at the tank for it.
so is this still an issue for the ones that removed the stock lift pump and fuel filter? if it is, what have yall done to stop this?
also, the water in fuel light, what do yall do to keep it from coming on?
Old May 26, 2010 | 11:17 AM
94 12valve's Avatar
When I put mine 150 in i had the old lines completly out of the tank before I unhooked them. I can't remember if I ended up plugging the stock suction line or what I did. I have the bed off so I'll look tonight.
I just unpluged my water in fuel light, hasnt come on since.
Old May 26, 2010 | 11:48 AM
crzycummins's Avatar
Old May 26, 2010 | 12:41 PM
12vcummins96's Avatar
same with mine the light never came back on
Old May 26, 2010 | 09:59 PM
94 12valve's Avatar
I just blocked it off
Old Jun 15, 2010 | 11:04 AM
Hightech_Redneck's Avatar
now as far as starting goes... i must have a leak some where due to if it sits for more than 10min the line is empty..... thing is that there is no fuel on the ground.... im checking near the motor cause it would look like oil then..... any tips or anything for it? im cleaning it with brake cleaner and trying soapy water
Old Jun 16, 2010 | 12:45 AM
since the line is higher than the tank and aridog itself, they will drian off, and not hae any in the top part of the line till u turn the key on, and it pressurizes it again. there isnt any check valves to keep pressure all the time on the line
Old Jun 16, 2010 | 09:54 AM
so then i should just let it run for 30 seconds before firing it up every time then?
Old Jun 17, 2010 | 10:25 PM
na, as soon as u turn the key on, and let the grids go off, fire it up. i have never had a problem with mine, and thats with just jumping in and turning it right over
Old Jun 18, 2010 | 01:40 AM
mine wont ever start like that then.... im going to check for leaks even though there is none on the ground..... hoping to get this fixed tomorrow
