im at a loss of coolant
Old May 25, 2010 | 05:14 PM
riddick01's Avatar
Default im at a loss of coolant
so...im loosing coolant probly a gallon every 2 to 5 days (depending on how much the truck is run)
ive pressure tested the reservoir and cap both held 16psi which is spec
ive got an egr delete so nothings goin through there
had the oil cooler checked and its not restricted
coolant temps are runnin between 190 and 210 so i dont think im boiling it
after a good hr of running i can pop the hood and smell coolant
nothing is pooling under the truck
only thing i can think of is its getting into the block but im not puttin out any white smoke so im confused as all hell
anything to help me keep my sanity would be awesome
thanks
jeremy
Old May 25, 2010 | 05:17 PM
bobcat67's Avatar
I know a guy who had a head gasket starting to blow and it ate through the coolant, didn't have any white smoke or anything, but his head gasket was blown, just not terribly bad, so who knows maybe that could be it, hopefully not though
Old May 25, 2010 | 05:22 PM
riddick01's Avatar
thats the only thing that i can think of but god i hope not...and the only way to really find out if it is a blown hg is to pull the heads
Old May 25, 2010 | 05:50 PM
Mdub707's Avatar
So I assume you have a white residue around the degas cap then? The cap will hold 16psi yes, but if the headgaskets are blown, they OVER-pressurize the cap and push coolant past it. My cap was in awesome shape but it was holding sooo much pressure when I went to take it off after running the truck for a while, it literally blew off and sounded like a shotgun going off. It hit the bottom of the hood and went flying out into the yard. That's a lot of pressure.
My guess goes to headgaskets.
You should log your engine oil temp vs. your engine coolant temp with your SCT and a labtop. Find a big hill and do a run up it, when you let off, check the temps. They should be real close to each other (something like 10 degrees apart and no more).
Old May 25, 2010 | 06:11 PM
riddick01's Avatar
biggest problem is i live in houston...a hill doesnt exist and most of our bridges are rather small
Old May 25, 2010 | 10:21 PM
ATX6132's Avatar
It is a slightly blown head gasket i have the exact same problem, it runs perfectly fine but after goin 75 for a while or pullin a load over 2000lbs it loses coolant and smells like burning coolant.. i replaced the resivor bottle the resivor lid..and lower radiator hose..still nothin..so i finally took it and got it dug into..passed pressure test..but still considered that i broke it down..and it was the head gasket was slightly blown from previous egr cooler and oil cooler gone bad. hope this helps
Old May 26, 2010 | 10:49 AM
riddick01's Avatar
thats exactly what ive got
ive figured it out. the past week my truck has been moving from spot to spot at my house (mostly around our barn thats got grass all around it). well now that all our guests have left ive finally seen it poolin up under the truck.
on a side note thanks for all the quick and helpful replies guys.
Old May 27, 2010 | 03:33 PM
riddick01's Avatar
turns out that it was leaking...and drinking...a hose was leaking but after they fixed that they say that it was raining coolant outta the cap and so it is a blown head gasket
so now my question is what gaskets should i use. the guy at the shop is tellin me that ford gaskets will be fine since im not gunna try to push the truck to 700hp but ive also heard that putting factory gaskets back on is doom and gloom and i should swap to something else
what yall think
Old May 27, 2010 | 05:28 PM
bobcat67's Avatar
what yall think
the Ford gaskets aren't worth it in my opinion, I'd get an ARP stud kit with Black Onyx gaskets, it's cheaper than buying the studs and the gaskets from ford, cause when my buddy did it they had to buy the head gaskets from ford and they came with the head bolt kit which i don't see the reason to pay for all that stuff if you only need the gaskets
Old May 27, 2010 | 05:49 PM
Mdub707's Avatar
The black onyx gaskets are the same damn thing as the ford gaskets, just coated with that "black coating" Get the victor reinz gaskets, they're the least expensive. There are 1000+rwhp trucks running these gaskets, I've never heard anything bad about the "Ford" gaskets either.
bobcat is right, no need to buy all that, just get the victor reinz, they're $47 per side.
