need some info on a tranny swap(auto to 5 speed)
Old May 25, 2010 | 03:45 PM
12vcoalroller's Avatar
Default need some info on a tranny swap(auto to 5 speed)
i need to know all the parts i need and what i need to do with all the auto sensors after the 5 speed is in
Old May 25, 2010 | 06:59 PM
tltruckparts's Avatar
the sensors arent needed when swapping i just took all mine off.
needs: tranny, 5 speed transfer case (if its 4wd), driveline mods, clutch, flywheel, clutch hydraulics (master and slave), pedal, clutch start sensor. i think thats mostly it.
Old May 26, 2010 | 07:33 AM
Subliminal's Avatar
I'm in the midst of the swap right now. I'd recommend just getting a whole donor truck.
Things I've picked up:
The tranny and transfer case are pretty important. The input splines are different from an auto to a manual, so you can't *easily* use your transfer case.
You're going to need the clutch housing/bellhousing adapter.
You'll probably want to buy a new clutch...it's too much work to put in a 1/2 dead clutch. Get one with the throw out, pressure plate, etc.
There are two big rubber donut bushings on the crossmember you'll definitely need.
Speaking of the crossmembers...the one I pulled off my auto is different than the manual one....I'd grab that, too.
You'll probably want to get a new pilot bearing for the flywheel. Also, you'll want to have the flywheel turned if you put a new clutch in.
The driveshafts are different lengths, as the trannys are different lengths...the front driveshaft on the 518 is a good 4 inches longer and the rear shorter.
You'll need the pedal assembly from the donor truck, as well as the clutch cylinder.
You'll need to cut a hole in the floor of the truck to put the stick shift.
And for my part, I needed a 4.5 inch grinder and a cut off wheel to get some of the crossmember bolts out. Those things were tough!
I've got a few page thread going on dtr about my swap if you want a little more info.
It's been pretty slow going...everything is messy, rusted, and heavy!
But, I'm a pretty slow worker...I've heard of people doing it pretty fast.
Oh, you'll also need a tranny or ATV jack..or at least it suuuure is a good idea!
Old May 26, 2010 | 05:30 PM
ya a tranny jack is key. it shouldnt take too long if you got everything ready. me and my brother had it done in a full day
Dertyd
24
Jun 7, 2015 02:45 PM
May 17, 2015 12:10 PM
wilki
Feb 12, 2015 09:04 AM
Ol Goat
Jan 22, 2015 02:16 AM
Ol' RED!
Dec 11, 2014 10:00 AM
