Transmission cant make up its mind?
Old May 25, 2010 | 08:21 AM
Zachdeagle's Avatar
Default Transmission cant make up its mind?
When accelerating from around 40-50, or when going up a hill, the transmission will go back and fourth between gears very rapidly, like it can't decide which gear to go in. It goes back and fourth from 1750 rpms to 2000 rpms very rapidly. Any idea as to what this could be?
Old May 25, 2010 | 10:21 AM
tltruckparts's Avatar
try the easy things first. make sure your tps is adjusted correctly and working
Old May 25, 2010 | 12:48 PM
12vcummins96's Avatar
Dodge diesel maintenance tips
here is a link on how to adjust the tps
Old May 25, 2010 | 01:38 PM
march diesel's Avatar
trans governor pressure sensor controls shift sensor my be bad or need filter change.need a scan tool to check governor pressure voltage if voltage jumps back prob and fourth probably need to be changed
Old May 25, 2010 | 07:52 PM
Zachdeagle's Avatar
Thanks for the info guys! I'm going to go ahead and start by checking the tps, but I wont be able to service the tranny untill this weekend. Is it safe to go ahead and adjust the front band now, and then adjust the rear band this weekend when I have the pan off? Or do I need to wait and adjust them both at the same time?
Old Jun 2, 2010 | 12:32 PM
glfredrick's Avatar
You can adjust the bands independently of each other. They don't care...
Adjust the TPS also. Might have to hog out the holes a bit to get it up to 1.2 -- 1.4 volts on the center pin at idle. That should help the shift points and also move the spot where the pot inside the TPS is slightly worn to another place where it doesn't bother you so much.
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
Trevlar11
Dec 11, 2014 03:30 PM
W350-4x4
Nov 12, 2014 09:35 AM
TheDirtyDozen
Oct 1, 2014 10:09 AM
