overhead console
Old May 24, 2010 | 04:05 PM
outlaw1_gt's Avatar
Default overhead console
Mt overhead console flashed CCD this morning wondering if anyone knows y?
Old May 24, 2010 | 04:20 PM
turbo20psi's Avatar
Chrysler Collision Detection (CCD)If your getting the CCD error the console is not getting a signal it needs.. You have a security system?Check for codes to.
Old May 24, 2010 | 06:08 PM
outlaw1_gt's Avatar
checked no codes.... no security system that i know of
Old May 24, 2010 | 06:42 PM
RAW's Avatar
RAW
I had the same problem, found a connector undone under the dash. It is near the large connector behind and to the left of the brake/clutch pedal. If there is a break anywhere with those 2 wire you will get ccd. If there are no other codes or symptoms, I'm betting there is a problem in one of those 2 wires.
The wires are a Purple with brown stripe, and White with Black stripe. They should be twisted to one another. They will also be at you PCM, ECM, and ABS module. I did a continuity test between my PCM and the wires at the overhead console to diagnose the opens in the wires. I'll try and get a schematic up for you.
Old Jun 13, 2010 | 09:23 PM
Bucket Truck's Avatar
Mine did this when a cab clearance light had leaked and the overhead filled with water. I fixed the leak and never had it happen again.
rack1234
Wanted To Buy (WTB) - Used
Mar 12, 2015 04:29 PM
rack1234
Mar 12, 2015 04:20 PM
IslanderXJ
Dec 17, 2014 04:14 PM
