LMM Performance Discussion of Chevy and GMC Trucks with LMM Duramax Turbo Diesel Engines Related To Performance And Longevity
Programmer for 2008 LMM
Old May 24, 2010 | 10:22 AM
flint400's Avatar
Default Programmer for 2008 LMM
I recently purchased the superchips flashpaq programmer. Does any know what kind of MPG gains I can expect on a stock gmc 4x4 with the DPF. Also will this programmer crap up the DPF? Thanks,
Old May 24, 2010 | 11:39 PM
The Superchips should be safe for the DPF. I'm not sure about mileage.
Old May 25, 2010 | 10:39 AM
TCU Fan's Avatar
Aaron
I don't think it craps up your DPF, but if you drive it hard you will probably get a code (I forget which one). It just means (check the code to confirm) to get out on the highway and let it regen, once its finished the code will go away and you are good to go.
My truck does that with the PPE set on the higher settings if I am driving it harder then usual. Not often but it has happened 4-5 times over the past couple of years.
JPatt
Jul 29, 2015 03:25 PM
Murdock
Apr 12, 2015 06:16 PM
cowpolk
Wanted To Buy (WTB) - Used
Jan 25, 2015 07:31 AM
aoutlaw95
9
Jan 5, 2015 07:21 PM
Renowest48
Dec 14, 2014 08:36 PM
