i f!@#ing broke it
Old May 23, 2010 | 10:07 PM
motown's Avatar
Default i f!@#ing broke it
i think i broke my input shaft or at least i hope i did and not something deeper in the trans i just had my timeing set to 16.5 the day before and i was trying to see how much better it ran well it run good enough to break stuff i wasn't slamin gears or jumping off the clutch just shifting easy and then rollin on the fuel 4th gear about 2000 rpm's she let go anyone have any ideas on good upgrade shaft without changeing the clutch
Old May 23, 2010 | 10:15 PM
dan33klein's Avatar
if you need a new shaft. you should just get the bigger billet one. but that will require you to get a new clutch. 13" instead of 12/1/4. but youll have a better shaft and clutch
Old May 24, 2010 | 12:31 AM
tltruckparts's Avatar
thats what i would do to. only problem with that is the 2k price tag (roughly)
Old May 24, 2010 | 05:22 AM
96dodgeplayer's Avatar
gotta pay to play, but you wont/shouldnt have this problem again
Old May 24, 2010 | 05:57 AM
94 12valve's Avatar
will the truck move in 4wd? if not its prob an input shaft.
Old May 27, 2010 | 09:41 PM
motown's Avatar
i have a 13 in clutch sb 3250 dd but i didn't get the bigger shaft like a dumbass
Old May 27, 2010 | 10:04 PM
94 12valve's Avatar
I thought all dual disks required the 1 3/8 input shaft
Just looked it up and the 3250 requires a 1 3/8 input shaft to work
Last edited by 94 12valve; May 27, 2010 at 10:04 PM. Reason: Automerged Doublepost
Old May 28, 2010 | 01:29 AM
12valvetater's Avatar
they will make you a DD with the small shaft. Just have the clutch sent out gone through and new hubs put in.
Old May 28, 2010 | 05:58 AM
94 12valve's Avatar
really? didn't know they would do that.
Old May 28, 2010 | 07:03 AM
96blackcloud's Avatar
yes depending on who you get your clutch from in my case i have a Kevlar single disc but i have the USA billet input shaft and had to call and tell them to put a 1 3/8 hub in it for me.
