Ignition On Power Source
Old May 22, 2010 | 07:55 PM
Uncle Bubba's Avatar
Default Ignition On Power Source
Where is a good supply for an ignition only power supply under the hood. Don't know why this is so hard but we stared at it for an hour today and can't find any.
Old May 22, 2010 | 11:51 PM
wildbill's Avatar
What are ya wiring up??
Old May 23, 2010 | 10:48 AM
Finally gettin around to installing the second electric fan on the cooling system gettin ready for the summer. The first fan is hooked to a temp switch to only come on at a certain temp and this one I want to come on with the truck ignition.
Old May 23, 2010 | 01:05 PM
chpmnsws6's Avatar
Its only going to be used as a trigger for the relay, so amp draw is very minimal.
*subscribed*
Old May 23, 2010 | 05:11 PM
RAW's Avatar
RAW
The fuse cluster int he cab is wired to ignition power. Power is only available when the key is on. There are a few spare fuse holders that you could use.
Old May 23, 2010 | 07:23 PM
We were hopin for somethin under the hood , just bein lazy. But ya it looks like it's gonna come out of the cab now. Thanks.
Old May 23, 2010 | 07:42 PM
01quadcab's Avatar
you can also run a switch into the cab and run the power straight off the battery. That way you have control and the fan doesn't have to be on all the time. This is how I hooked up the transmission cooler on my truck.
Old May 23, 2010 | 07:57 PM
Were hookin em up s that one fan is on low all the time, the other will turn on low when the truck hit's 210 degree's and both fans will have a switch that gives me control of the high setting on them. There drawing power through a relay, the wire for the ignition is just for a trigger to turn the fan on.
May 10, 2015 10:57 PM
explorer197143
Dec 28, 2014 01:14 PM
