Vp44 Question?
Old May 22, 2010 | 11:36 AM
98dodgecummins's Avatar
Default Vp44 Question?
Is the vp44 pump just not made for chips or if you get a good lift pump that keeps 17 psi at all times. Can a vp44 last forever if you have a good lift pump or is the vp44 just cant handle a tapped pump for very long?
Old May 22, 2010 | 01:13 PM
crzycummins's Avatar
a vp will last plenty long if you supply it with the fuel it needs. if you dont on the other hand give it the fuel required for your setup then you will be replacing it more than any of us would like. looks like your doing ok if your psi is around ten at wot but once you get below that its probably time to upgrade to keep psi up. as is said all the time make sure you have a fuel pressure gauge if you dont already.
Old May 22, 2010 | 01:27 PM
FRIDAY88's Avatar
Well lets just put it this way Big chip Stock lift pump bey bey VP44 Big Chip and Over 17psi supplie Bey Bey VP44 if i were you just go with an Airdog or FASS fuel system and make sure its not over or under around 17psi and you will be fine ..
Old May 22, 2010 | 01:33 PM
Not true.
Old May 22, 2010 | 02:44 PM
Ive seen stock pumps untapped last 150K+ Miles. Mine has 130K Tapped miles and its running fine. Some last and some do not. 9 times out of 10 if you give your VP44 a good supply of fuel it will last 100K+ miles.
Old May 22, 2010 | 03:43 PM
well the bad thing about my fass ddrp is that it pushes 20 psi at idle and whenever it gets up to that psi my truck starts having a slight miss to it? what could this be?
Old May 22, 2010 | 04:22 PM
FRIDAY88's Avatar
If your not carefull you will end up blowing out the diaphram in it running that much pressure idont own a cummins but ive seen these pumps take a Sh*t from running tooo much fuel supplie pressure I get all this Info on the VP44 and CP3s From My good Friend Dan Stays in good touch with 2009 Diesel power champ Robert Evans who lived no more than 60 miles away from me in Cresent Valley Nevada With His 04 cummins twin CP3 pumps this guy nows his stuff
Old May 23, 2010 | 07:49 PM
mine lasted about 140,000 and probably still had some left but i decided to upgrade....i agree here. if you give it a good supply then it should last you for a hefty length of time...
Old May 23, 2010 | 07:57 PM
FRIDAY88's Avatar
you get a good supply pump and no worries about it
Old May 31, 2011 | 12:17 PM
daddyka's Avatar
i have a question about a vp44 pump.i replaced the transistor and it still burning one of the wire.please help me!!!!.any response is welcome
