General question
Old May 22, 2010 | 10:33 AM
bkg10's Avatar
Default General question
Hi everyone, I just purchased an 02 xcab 2wd to tow a 5th wheel around the country. I have a few question for anyone with more knowledge than me. Am I in the right place?
Old May 22, 2010 | 11:23 AM
It depends what is your question?
If its general questions about your truck you should be posting here:
24 Valve 2nd Gen Dodge Cummins 98.5-02 - Diesel Bombers
If your questions are about performance or aftermarket parts you should be posting here:
5.9L 24V Bombs (Aftermarket) - Diesel Bombers
Thanks for asking and Welcome
Old May 22, 2010 | 11:39 AM
bkg10's Avatar
Default Thanks Dr.
I am interested in some potential upgrades. My truck has almost 200,000 miles. Is it worthy of an upgrade? Should I focus more on maintanence?
Old May 22, 2010 | 03:14 PM
Hows it running? Any codes or problem?
Old May 23, 2010 | 06:53 PM
bkg10's Avatar
Default 02 Cummins
Hi, It runs great. Did have the TPS trouble code, replaced that, pretty spendy. I have come to learn that is a common problem. It appears that the fuel guage doesn't read properly, it started to or appeared to begin running out at a 1/4 tank.
Old May 24, 2010 | 04:55 AM
96dodgeplayer's Avatar
sending unit prob on the fuel gauge. its common, i just replaced mine. i have a 12v tho. it has over 250xxx miles, still ran perfect, and i just started upgrading the truck
Old May 24, 2010 | 08:25 AM
bkg10's Avatar
Default Fuel gauge
Thanks for the info., good to know. Is the sending unit the pump also? All in one in the tank?
Old May 24, 2010 | 02:00 PM
i dont have the part number handy but you can buy just the "sending unit float leveler" from the dealer only. for around 70$
otherwise you can replace the whole module inside the tank which i believe is called "Fuel Tank Reservior" but that is approx 300$ at rockauto.com
i had to replace the whole module because mine was rusted away and fell apart in my tank. but i hear lots can get away with just replacing the float arm.
Old May 24, 2010 | 03:19 PM
bkg10's Avatar
Thanks. That's good info. What would be your reccomendations for my use, I tow a 26' 5th wheel from state to state, usually disconnect for a few months and then use the truck daily sometimes 200-300 miles. Thr rig runs good now, tows well and the such, I just want to make it last. A little more "umph" wouldn't be bad either.
Thanks again.
Old Jun 8, 2010 | 04:06 AM
havasued's Avatar
The best thing is to take it to a good diesel guy and have him check it out real good, compression, valve springs, hoses, belts etc., then you can decide what if any upgrades you need. My 98 12 valve has 130,000 miles on it and mantainence issues keep cropping up.
Dodge2006/5.9
Jul 20, 2015 01:21 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
Down South
Jan 11, 2015 01:33 AM
countryboy040993
Dec 31, 2014 05:10 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
