turbo regulator?
Old May 20, 2010 | 11:08 PM
jdcoop8791's Avatar
Default turbo regulator?
I want to regulate the amout of boost my 94 6.5l tdi makes. has anyone made something to do thing or knows where to get something like it cheap. i would like to be able to do it from the cab. i can take of the vac line off my engine and make no boost but a want a little when i need to smoke people out , but be able to have the boost for power when i need to get away fast:88 . so i hope someone can help me out with some pictures or web sites
Old May 20, 2010 | 11:17 PM
Woody35's Avatar
not from the cab but you can do it underneath the hood. Turbo-Master MODEL GM Boost Control
Old May 21, 2010 | 08:16 PM
2MuchJunk's Avatar
They used to make a controller that hoked into the turbo solenoid and had a dial mounted in the cab to control the turbo. I can't remember who made it and if they still do.
Old Jun 10, 2010 | 01:04 PM
purcell87's Avatar
Try this out.
GM 6.5 Turbo Diesel Boost Control, Dash Mount ADJUSTABLE !
Old Jun 11, 2010 | 12:12 AM
Woody35's Avatar
dont check out the above link and please dont buy it. its a scam. the guy is a troll and it will not work. guys nickname is steaksauce because his company name is a1 llike the sauce. look him up in the better buisness burea. lots of complaints!
Old Jun 11, 2010 | 10:34 AM
purcell87's Avatar
Sorry man, i didnt know. I never did any business with him, and just came upon it in a search. thanks for the heads up though..
Old Jun 11, 2010 | 06:18 PM
2MuchJunk's Avatar
Them are the ones. Guess I'm glad I didn't buy one years ago when I was looking at them.
Old Jun 12, 2010 | 12:45 PM
muderxtreme's Avatar
I made a manual boost controller for my 94 out of a spring and an eyebolt, then fabbed up a mount where the stock vaccum controller was. I'm still working on some way to controll it from the cab. It works good, but it takes some tikering to get the spring rates right. I wouldn't suggest doing it unless you have gages (boost psi and egt) because it pretty easy to put too heavy of a spring on there and make too much. The whole thing cost me about 5 bucks from the local hardware store and some southern engineering. ill post back if I can figure out a reliable way to controll it from the cab.
Old Jun 13, 2010 | 09:34 AM
Woody35's Avatar
i love homemade turbomasters. easy to turn up boost and cheap to make
Old Jun 13, 2010 | 01:51 PM
purcell87's Avatar
did you delete your vac pump then?
