ball joint
Old May 19, 2010 | 11:55 PM
cumminsCrazy's Avatar
Default ball joint
ball joint removal help how do i get the steering knucle off everything is off but stuck on ball joint removal?
Old May 20, 2010 | 07:48 AM
oglejust's Avatar
sledge hammer hitting down, dont mess up the surface the wheel bearing bolts to. that or hit on the side where the ball joint tapers into the axle... i had 2 use the sledge hammer trick
Old May 20, 2010 | 08:30 AM
trucky's Avatar
go get a ball joint press
Old May 20, 2010 | 05:12 PM
oglejust's Avatar
i thought the knuckle was stuck on the truck, the ball joint removal takes a ball joint press
Old May 21, 2010 | 09:23 PM
stevenbrazell's Avatar
yeah, i couldnt get the knuckle off either, and i started to deform the top of the knuckle.
Old May 21, 2010 | 09:33 PM
dan33klein's Avatar
any tips on pulling the hub?
i heard its imnpossible to pull the hub without destroying the bearing?
sorry to hyjack the thread
LawdawgSHPD
Aug 21, 2015 06:23 PM
oznation
May 26, 2015 09:23 AM
nickpro902
Mar 14, 2015 08:46 PM
99RAMS
Tire, Wheel & Suspension
Jan 25, 2015 11:31 PM
A Bit Hick
Oct 23, 2014 03:22 PM
