help id this holset turbo
Old May 19, 2010 | 11:31 AM
hightops76's Avatar
Default help id this holset turbo
I need to know what turbo this is,was told its a hx40. and im not sure what size also, did some messurments but its in mm and I see they check in cm. im guessing its a 58 compresser and a 16 exhaust outlet. I took pics of the #s on it, but no tag on charger just some #s stamped on it. tryed it out, its takes a few secs to spool up, didnt see much of and increase from my hx35. I hope someone can tell me what I have and if any good or not. its a 8 blade wheel. thx
Attached Thumbnails help id this holset turbo-p1010189.jpg   help id this holset turbo-p1010188.jpg   help id this holset turbo-p1010187.jpg   help id this holset turbo-p1010184.jpg   help id this holset turbo-p1010183.jpg
help id this holset turbo-p1010182.jpg   help id this holset turbo-p1010181.jpg   help id this holset turbo-p1010180.jpg
Old May 19, 2010 | 05:32 PM
dan33klein's Avatar
pull the comp housing and measure the wheel.
looks pretty beat up
Old May 19, 2010 | 09:52 PM
hightops76's Avatar
I can do that, but I was hoping someone could tell buy the #s and by looking at it. I was told it was a hx40 with a 16 exhaust housing what do you think?
I hope its not a fake holset that ive heard about
Last edited by hightops76; May 19, 2010 at 09:52 PM. Reason: Automerged Doublepost
Old May 19, 2010 | 10:16 PM
DieselWeasel's Avatar
"Ohio Bombers" Director
Kinda crappy, your name plate was removed... Wonder if it was removed on purpose? The name plate would tell you everything you needed to know
www.cummins.com/turbos - identify your turbocharger
Old May 20, 2010 | 09:14 PM
hightops76's Avatar
yea I know, but someone must know what this is I hope
I did look at holsets id site, with no luck, my #s dont match up, but hard to think with the holset stamped on both the compresser and exhaust that its a fake
nobody can id this turbo? do I have to take all apart to see what it is?
guess I will have to try another site
Last edited by hightops76; May 20, 2010 at 09:14 PM. Reason: Automerged Doublepost
Old May 20, 2010 | 09:27 PM
tltruckparts's Avatar
it could very well be an hx40 they made 8 blade 56mm and 58mm wheels and they did make a 16cm housing. not sure but it very well could be
Old May 21, 2010 | 11:49 AM
wildman6bt's Avatar
That is a 7 blade for you all that can't count lmfao. I have a super HX40 its a 60/85/16 so just measure the comp wheel this might narrow it down.
Old May 21, 2010 | 12:31 PM
12vcummins96's Avatar
it is an 8 blade so you need to recount again and yes it is an hx40 just old and wornout
Old May 21, 2010 | 10:07 PM
hightops76's Avatar
yes its an 8 blade, so its a 58/something/16 and then I can just buy a rebuild kit for it right. would I be able to change it to a 6 blade, they say that 6 is the way to go. or is it not worth it to redo.
avatardvr
18
Aug 8, 2019 12:38 AM
Cumminsfreak24
May 6, 2015 04:56 PM
truckeez
For Sale
Mar 3, 2015 05:54 PM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
