confused
Old May 18, 2010 | 05:53 PM
swelbe's Avatar
Default confused
i have a 95 cummins i put a big cone air filter on , moved the plate ff , the afc ff ,star screw 1/4 way from front an all i seem to be getin is just alitte more power an alot of smoke not much boost so then i pinched the waste gate line an nothin happened , so the i pluged the line an nothin . so is there something im missing ? i cant run with my buddys 96 cummins an he hasnt done nothin to his pump. app. the help
Old May 18, 2010 | 07:07 PM
95cumminsguy's Avatar
check you intercooler boots one or more of them might have a hole in it that could very well be your problem.
Old May 18, 2010 | 07:32 PM
You should be getting a real good puff of black smoke if you have a hole or cut in a boot.
Do you have a boost guage?
Old May 18, 2010 | 07:53 PM
12vcummins96's Avatar
yeah i say the same gotta have a boost leak what psi are you runnin
Old May 19, 2010 | 03:21 AM
96dodgeplayer's Avatar
tell us your boost gauge psi.
i bet you have a small leak on the passanger side by the intercooler
Old May 19, 2010 | 06:15 AM
swelbe's Avatar
i havent put a gauge on it yet workn on that one. i have a big puff of black smoke then goes alitte blue or white cant really tell .. an if i lug it down u cant see behind it for the smoke.
Old May 19, 2010 | 06:52 PM
99.5 % sure its probably a torn boot
Old May 19, 2010 | 07:11 PM
monster12valve's Avatar
x2 on the boot leak...
Old May 21, 2010 | 10:52 PM
diesel_addict's Avatar
second that
Old May 22, 2010 | 10:43 PM
wes-cummins's Avatar
put a boost gauge in there would b a good idea
