Added some power..first mods
Old May 18, 2010 | 04:12 PM
Wellused's Avatar
Default Added some power..first mods
Well,after driving it for over 1 yr totally stock,made some changes today.Cat is history,K&N and an Edge EZ..all I can say is I cant believe I didnt do this a year ago.Even on lowest setting,it is a different truck.The throttle response is awesome.I wasnt after more power,but the Edge smoothed the motor out and took out what I can only describe as a dead spot in the pedal.Its on its way to Florida this weekend.I will keep an eye on my mpg's and see.I have to tow about 8k lbs plus trailer.It says tow safe in lowest setting,hope so,cause gauges arent here yet.
Old May 18, 2010 | 04:19 PM
ArizonaRedneck's Avatar
well good sounds like your happy with it and welcome to diesel bombers good luck to you
Old May 18, 2010 | 04:22 PM
Wellused's Avatar
Thanks..I will never own a gasser(truck) again.This truck has such a wider powerband than my old 1st gen.
Old May 18, 2010 | 10:19 PM
dangerous1965's Avatar
What state are you in? Hope there is no smog laws looming in the future! Don't throw the cat away!! Send it to me! Fill out your sig for your truck!
Old May 22, 2010 | 05:38 AM
Wellused's Avatar
I saved the cat.I am in Ohio,we dont test yet.
22.0028 mpg unloaded with the Edge on 25 hp setting.Used same pump to refill to get these figures.Got almost 2 mpg more on a steady,non loaded run.
Old May 24, 2010 | 09:28 PM
MossyOakRedneck's Avatar
sounds good man
May 10, 2015 10:57 PM
explorer197143
Dec 28, 2014 01:14 PM
