HELP! Truck is dead!
Old May 18, 2010 | 07:34 AM
woodly1069's Avatar
Default HELP! Truck is dead!
Yesterday as I was trying to get home from work I was traveling about 40-45MPH and decided to hit the O/D off button to keep the truck from locking up before a hill with traffic on it. When I did that I lost the Tach and ALL of the lights on the dash flashed and then went off. The speedo, volt meter, oil pressure etc. still work but now I have no tach at all. To make matters worse, it seems that the thing did lock the torque converter or something because it feels REALLY sluggish when trying to take off. I did manage to get the truck about a mile and a half to the house but even after checking all the fuses and resetting the ECM by unplugging the battery I have no tach and I'm sure it's stuck in lock mode or something. Since the diesel has no ignition coil, where does it get it's signal for the tach and if this sensor dies will it cause the ECM to freak the tranny out? Any help is appreciated as this truck is my daily driver!
Old May 18, 2010 | 09:14 AM
94 12valve's Avatar
there is a throttle pos sensor on the throttle linkage. The tach sensor is on the timing cover it reads off the damper.
Old May 18, 2010 | 12:13 PM
woodly1069's Avatar
yeah that's kinda where I was heading with this, guess I should check that first.
Just in case anyone else sees something similar, the crank sensor wires were cut by the belt! Easy fix, stupid move on my part I guess! Thanks!
Last edited by woodly1069; May 18, 2010 at 12:13 PM. Reason: Automerged Doublepost
Old May 18, 2010 | 01:10 PM
94 12valve's Avatar
wow, glad you got her fixed
burndiesel
10
Feb 7, 2023 01:15 AM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Oct 14, 2014 08:40 AM
Sep 30, 2014 10:00 AM
