Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
Puller Newbie Question - Rules ? for local event.
Old May 17, 2010 | 08:25 PM
DieselWeasel's Avatar
"Ohio Bombers" Director
Default Puller Newbie Question - Rules ? for local event.
So they have some stock 4x4 pulls @ Yankee Lake Truck Night. I want to give it a shot since its only 10$ per hook. The rules state "6800 lb (max) gasoline street stock 4 X 4 truck & 8500 lb (max) diesel street stock 4 X 4 truck". So is that GVWR?? Since i have the 8800# GVWR rating does that mean i cant run... OR are they saying the truck can only WEIGH 8500# at weigh in??
The link for the event is here... Truck Night at Yankee Lake: Schedule under July 16th... If your local you should attend!
Thanks everyone!
Old May 17, 2010 | 08:26 PM
GetBlown5.9's Avatar
goes by actual truck weight, GVWR means nothing
Old May 17, 2010 | 08:35 PM
Sweet thanks! So i should load her down for the pulll then?? Since Ill be just doing it for fun is it worth loading down with weight??
Old May 17, 2010 | 08:57 PM
94 12valve's Avatar
is your truck and auto or a stick?
Old May 17, 2010 | 09:15 PM
Automatic
Old May 18, 2010 | 05:53 AM
94 12valve's Avatar
a stock auto? might not be a good idea to hook to a sled
Old May 18, 2010 | 07:11 AM
powerdbycummins's Avatar
you should come hook. i go to trucknite all the time its a good time there. if you cant hook to the sled they got the tug o wars goin on to. come check it out
Old May 18, 2010 | 08:07 AM
Yes its a stock trans... That's why I wanted to do a run for fun.
I'm assuming if I were to run then I shouldn't turn my Adrenaline up very high? To save the trans.
What really needs done t the trans to make it strong? Is it a ton of $$?
Old May 18, 2010 | 09:09 AM
94 12valve's Avatar
if you have a hd t case it will be fine.
If you hook run in 4 low, you prob is gonna be that your gonna be on the TC the whole pull.
Old May 18, 2010 | 11:55 AM
What do u mean about the TC?
