Transfer Sled Pulling Diesel Discussions of Transfer Sled Pulling , Set Up , Designs , Practices , Techniques , Tips and More
*PLEASE DO NOT POST FUTURE EVENT DISCUSSIONS IN THIS SECTION*
Got her to turn some RPM!
Old May 17, 2010 | 06:55 PM
94 12valve's Avatar
Default Got her to turn some RPM!
Left the line at 5k and carried 4200 rpm down the track. 3rd low, 3.54's, and a 33 inch tire.
Now I need to get some front weights and tweek some other little things to help it hook better. Im very happy with the way the truck sounds now
Old May 17, 2010 | 07:02 PM
dirt diggler's Avatar
that sounded dam good nice run.
Old May 17, 2010 | 07:40 PM
DieselWeasel's Avatar
"Ohio Bombers" Director
SICK.... So is the throttle burping at the end of the run YOU or the engine? If its you doing it, why?
Sorry if thats a newbie question but ive never pulled.... Yet....
Old May 17, 2010 | 07:50 PM
Red_Rattler's Avatar
High Tech Redneck
Sounds like the big boys to me! What springs (gsk + Valve) are ya running?
Old May 17, 2010 | 08:06 PM
AF1CUMMINS's Avatar
how in the world you get a Cummins to turn five grand?
Old May 17, 2010 | 08:12 PM
GetBlown5.9's Avatar
P7100 injection pump on a 12v with 5k governor springs and the supporting mods in the motor to handle the abuse.
Old May 17, 2010 | 08:46 PM
94 12valve's Avatar
Scheid 5k springs and Hamilton diesel srpings and retainers
I like to bring the turbo down as easy as I can. I burp the throttle at the end to give the motor some extra raw fuel to help cool things inside down and slowly bring the rpms back down.
Bingo thank you TJ, your rund at the buck sounded awesome
Old May 17, 2010 | 11:40 PM
biged681985's Avatar
nice pull dave
Old May 19, 2010 | 05:17 AM
80powerwagon's Avatar
sounds good, how much weight can you hang? If you can keep the wheel speed up when hanging weight should do pretty good, you need to have a lot of ground speed and maintian it the whole run, it looked really good
Old May 19, 2010 | 09:10 AM
94 12valve's Avatar
I can hang 1400lbs and be right at 8,000lbs.
my wheel speed is right arround 25mph, but you are right I need to improve my ground speed. hanging some weight should help a good bit with that tho.
