Rear Window Removal?
Old Sep 21, 2007 | 01:25 PM
DazedandConfused's Avatar
Default Rear Window Removal?
Does anyone know an easy way to remove the rear window out of a 94-01 Dodge ram? They are glued in and I need to know the easiest way to remove them. I found a ton in the local junkyard just need an easy way to get them out.
Andy
Old Sep 21, 2007 | 01:28 PM
bow2no1's Avatar
sure, you can try a torch and a putty knife or a guitar or piano wire .... work your way around real slow
Old Sep 21, 2007 | 01:29 PM
Whit's Avatar
Site Mascot
never messed with glass................I wanna know to eh
Old Sep 21, 2007 | 01:38 PM
Well they also have metal clips if I remeber right when taking mine out. Glass company wants $600 for a new one. I can get one at the salvage yard to $50 and have installed for $50
Old Sep 21, 2007 | 01:43 PM
Uncle Bubba's Avatar
I've never done one on this truck, but on others I have done you just pry out a piece of the rubber seal and then start pullin your way around the window. Once you get it started it's pretty easy from there. Some use a solid 1 peice rubber seal and some use one with two ends that meet up. If it has the two ends just start at one of the ends. It's just like a rubber grommet that holds the window in place with outward pressure.
Old Sep 21, 2007 | 02:02 PM
Yeah I have done the one piece seal ones but mine was glued in. I broke mine taking it out.
shingi
Off Roading
Sep 30, 2015 11:17 AM
yfzrunner
Sep 17, 2015 05:23 AM
Machinist
Jun 23, 2015 06:57 AM
southern dieselnorth zip
May 18, 2015 01:02 AM
