Glow Plugs 2004 6.0 125,000 miles
Old May 16, 2010 | 07:57 PM
Flyin200's Avatar
Default Glow Plugs 2004 6.0 125,000 miles
2004 f-350 6.0 125,000 miles,
Do glow plugs act like spark plugs when they are getting bad. I have a random sound like spark knock when i am on the highway. I have deleted EGR and rebuilt oil cooler. Turbo sounds good. Use diesel power service summer additive every tank.
Old May 16, 2010 | 08:31 PM
Mdub707's Avatar
No. Nothing like it. They are used to pre-heat the cylinders to fire the motor when it is cold. Once the truck is running they really serve no purpose (on these motors anyways). My guess is injector going bad possibly... When's the last time the oil was changed and/or the fuel filters?
Old May 17, 2010 | 07:47 AM
Diesel Powered Rocket's Avatar
Have you checked for diagnostic codes?
I would check to see if your FICM is securely mounted (located on left valve cover) and that the rubber vibration insulators are intact on the 4 FICM mount locations and the 2 valve cover mounting studs.
Then I would check the injector wire harness for worn insulation or a loose or missing injector connector clip.
You may have an intermittent open injector circuit due to a loose connector or you may have an injector that is grounding out from time to time due to worn insulation.
rkp209
Chevy/GMC Duramax 2011 LML
Jan 10, 2016 10:32 AM
GT_Eleanor
Sep 14, 2015 10:52 AM
JaysTruck
Jul 22, 2015 11:49 AM
hardwired
8
Jan 23, 2015 04:30 PM
dieselbomb
Dec 19, 2014 12:08 PM
