24 valve cutting out, need help
Old May 16, 2010 | 05:16 PM
guroo987's Avatar
Default 24 valve cutting out, need help
been a while but here goes.
lost injection pump at 129,000, bought special x from blue chip, installed with no problems, fired it up and idled perfect, let it warm up and took for a test drive and it was cutting out at all rpms except at idle. now when i say cutting out it would just die for a milisecond and come right back, perty violently. called chip and he said it is a apps problem cause it doesnt do it at idle, only when the apps goes into closed loop. he suggested i check the connections, i did and they were all good. problem went away i thought until i took it on a 400 mile trip and it did it about 20 times cruising at 75 mph. next day no problem again. about 2 weeks go by and it is back at all rpms again but intermitent. never had a prob until changed IP. recalibrated apps and it was way out of range, within .01 volt now with no change. today whwn it acted up it was doing it at idle in gear to but not in neutral. fuel press is always between 16-13. does it with chip on or off. IP does have one of chips stelth covers on it. ANY HELP APPRECIATED!!! THANKS IN ADVANCE!!! AND NO CODES!!!
Old May 16, 2010 | 05:23 PM
Could still be a APPS issue.
Old May 16, 2010 | 06:08 PM
guroo987's Avatar
it seems like an apps issue but it is hard for me to buy a new one when there was no problem there before the new injection pump
Old May 17, 2010 | 07:32 PM
guroo987's Avatar
anybody???
Old May 19, 2010 | 10:50 PM
jkidd's Avatar
Any codes? If you need a new apps or tps don't buy it at the dealer. you can get them for less than $200.
Old May 20, 2010 | 07:07 AM
RAW's Avatar
RAW
How about your Cam sensor or wiring to it? Tricky little devil hides behind the VP, so it is hard to test. I don't suppose you changed the sensor when the P was removed?
Old May 20, 2010 | 09:26 PM
guroo987's Avatar
no i did not change the sensor. and there are NO CODES
RA113024
Mar 13, 2016 07:42 PM
jeremiah1
Jul 21, 2015 06:35 PM
LTreis702
Feb 14, 2015 12:52 PM
bonestock
Feb 1, 2015 08:41 PM
woodsman27
Oct 26, 2014 02:13 AM
