steering gearbox
hi im going to be replacing my steering gearbox on my pickup i got the general idea u know remove the lines the pitman arm the three mounting bolt not so sure on how the steering shaft comes off but if u guys have any advice tips hints that would be great and theres bound to be at least one of u who had to do this with the way dodges steering is anyway thanks for readin.
the steering shaft has a pinch bolt. just take out the bolt and pull the gearbox away. I recommend not getting a rebuilt box as I just went through that. I am pretty sure all they do is replace the seals. If there is anything wore out in the box they dont care. The steering box brace is worth the 200 bucks. I wouldnt trade mine for nothing. Hope this helps ya.
seems like it was 11/16 but i am not sure. I took out the inner fender well on the driver side to give a little better acces. Its also good to check your intercooler boot while your down there. Mine was getting cut by the body. Just took some pleirs and bent it out of the way. good luck.
thanks for all ur help 94 i was able to get it out the pitman arm was a pain i think i pulled my bicep
breakin that sucker lose but i definitly couldnt have done it without ur advice.
