fuel pressure
Old May 15, 2010 | 10:40 AM
junkyardkid69's Avatar
Question fuel pressure
I need to get a guage on my fuel but i have a couple questions where do i hook the guage up and how many psi should it be runnin and also any refurals on guages? Thankyou
Old May 15, 2010 | 10:54 AM
On a completely stock truck - you need a 1.8" npt fitting - goes in the forward port of your fuel filter housing (DO NOT forget a needle valve or pressure snubber to dampen the pressure spikes):
Old May 15, 2010 | 10:56 AM
psi depends on the shape of your lift pump. You will want a minimum of 5 psi at Wide Open Throttle.
Old May 15, 2010 | 10:19 PM
cummins24's Avatar
Do I have to use the isolator with my isspro fp gauge? I have a needle valve before the isolator but the reason I ask is because the bleeder screw on the isolator doesnt want to seal anymore.
Dbleo351
Nov 20, 2016 09:34 AM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
powerstroker13
94-98 7.3L Performance
Oct 30, 2014 02:57 PM
cummins Pride
Oct 6, 2014 11:28 AM
